Fuel system check valves installation
MoDawg73
Hello all,
Just pressure tested my fuel system and only found 3 leaks! Classic!
In the process, I figured out that the pressure relief valve is stuck closed. So I am going to replace that and the air inlet check valve. Just had a quick question.
I looked at the ski and the parts diagram, and it looks like they are just inserted into a grommet that’s goes through the hull. Is that correct? Can I just pull them out through the inside of the hull? Any help would be greatly appreciated!
Thanks,
Ken
