Hi all,
I just picked up my first pair of PWCs. One is a 96 GTX. I'm taking all the advice I've read and replacing all the gray fuel lines and putting rebuild kits in the carbs. I also am going to pull the fuel pickup and check for debris in the tank and replace the fuel strainer.
I replaced the selector switch and the filter under the steering is clean.
I want to be sure I understand how the fuel pickup works. Am I correct that there is nothing mechanical in the pickup that actually pumps fuel? It's truly a pickup, yes? Meaning that it sucks up fuel by the fuel system creating a vacuum basically?
There are two pickup hoses, one stops about 2 inches or so before the other so that the final portion of fuel is reserve. Do I have that all right?
When I pull it, other than the strainer and checking for yucky stuff in the tank, what other things should I be looking for?
