fuel issues
cholmes10957t
i have a 96 seadoo gtx i am not getting fuel to the carbs at all i dont know what to try this is my first jet ski any ideas?
double post
bad o-ring in the inline filter or bad/clogged fuel selector switch
Mark the oil tank to be sure it is drinking so you do not burn out, any air leak to the fuel system will make a lean condition, many times the rubber ring seal in the reserve switch breaks then goes into a hole blocking the fuel flow, take it apart and new rings or a new one cost about 25bux, clean the water/fuel filter under the handlebars to get any steel gas can trash out of there so it can not go into the tiny carb filters.
