Fuel Guage on 2003 RXP
Okybrian
Need some help, the fuel gauge on my 2003 RXP 4-tec Supercharge is not working. It has been setting for a couple of years. Any ideas?
So, is it not working as in you can't see it at all or is it showing incorrect fuel level?
If it's showing inaccurate level, you're fuel level sensor is probably stuck. I had one get stuck in the low position and would cause the ECU to continually sound the low fuel warning beep.
There was no 2003 RXP, first year was 2004 in black/green or yellow/black.
Most of the RXPs that I've seen with fuel level problems ended up being ECU. Check the resistance of the 2 fuel float signal wires. 0 ohms for full tank, 90 ohms for empty tank.
