get_real
The fuel gauge on my 96’ XP was working perfectly when I parked it about 3 years ago. Now that I’ve got it running again the red light on the gauge won’t go off regardless of the fuel level. I pulled the baffle out and the float and screen look fine. I should have checked the resistance while I had it out but didn’t. I then pulled the 6 wire plug that goes to the gauge and checked resistance from the pink and pink/black wires and measured about 16 ohm’s which per my manual shows the tank should be about 7/8 full. It’s actually about 3/4 full. Does this mean the gage has gone bad? The manual talks about using a potentiometer to test the gage but I don’t have one. Any thoughts on other tests I should do before replacing the gauge? All the other lights on the gauge are working correctly.
