Fuel and speed gauge not working
These are common problems.
For the speedo, normally the little signal converter on the Speedo sensor goes bad. You would have to replace that. Most think the cost is not work the fix of the inaccurate speedometer. If you decide to pursue a fix, there is some threads here that will show how to test the gauge or the converter. Make sure of which component is bad before replacing. Make sure the little spin wheel is still intact and spins freely on rider plate rear left of nozzle.
For the fuel gauge, it is most likely the little .5 amp fuse that SeaDoo decided to include on a circuit inside the fuel baffle of the tank. Here is a link that will help you determine and fix problems with that one... http://www.seadooforum.com/showthre...ght-on-when-tank-is-full-(fuel-baffle-sender)
