1983
For Sale: 98' Seadoo XPL 951 engine. Would prefer to sell local but can ship. Can email or txt compression test videos if you PM me your contact info.
Engine will come with carbs, starter, bendix. One of the plastic barbs for the fuel lines is broke on the carbs, one brass nipple for the oil injection on the block will need to be replaced or straightened out. Or could go premix. Engine had been rebuilt by previous owner, I do not know the extent but am guessing at least a top end.
Compression test done on cold engine, with throttle closed ( cable was stuck ) So compression should be higher when engine is warmed and lubed up well and carbs are held wide open for a proper compression test.
Cyl 1: 111 psi
Cyl 2: 117 psi
$675 obo shipped CONUS
Pretty good deal if you consider cases alone are $225 and up.
Rob
Located in Raleigh, NC 27615
Cyl 1: 111 psi
Cyl 2: 117 psi
Rob
