DnKSeadoo
First thanks for everyones continued help. Which brings me to my next problem with this boat we recently purchased. I pulled the carbs apart for the surging problem and found the basket plugged on the pto carb. Was happy to find it and put it back together for a test. Hooked up the hose and it ran really good better than ever. Then I noticed a water leak from between the jug and lower half of engine. Slightly unhappy but confident I could fix after reading many post and looking at the repair manuals. So I dis-assembled the engine and am now ready to take a hole saw to the hull and float it out on lake erie! Here is what I have it is a 717 motor that has silver jugs and a worn pto piston. The mag side cylinder is perfect but under closer inspection it seems that the sleeve as replaced with a 0020 one and the pto one is standard. So just wondering if any one has had any luck with a cheap fix on something like this?
