Fogging a 2001 gtx di
whimbly1
I have looked at the manual and really can not tell exactly where the fogging oil is sprayed. can someone give me clearer directions for doing this? Also, I have a can of stabil fogging oil; is this okay to use?
Spray it in the intake, remove the plastic tube and spray it at idle till it stalls. The idea is to coat it internally to protect it from corrosion.
Karl
Thanks. The manual indicated that there is a port built into the intake so the tube doesn;t have to be removed. Do you know why it would indicate that. However, I will spray it directly into the air intake in the morning.
Thanks,
Ben
