OrangeAnimal
I have a problem (I think) when I hook up the hose to my 2000 Challenger M2 carb 2 stroke engine. Water comes out into the bilge area. It only comes out on the same side the hose goes into the engine. So I checked the hose first. Did not find anything wrong there. It's coming out around the base of the engine. Where its mounted to the hull. I gave the guy a call and he says this is normal! I really found it hard to believe cause it's a fair amount of water coming in. Any info on how the cooling system works on the M2 engine in general would also be appreciated as well. Should this be happening? The PO says it doesn't do it when in the water and I have seen the boat run but it was from the shore and on a video but not personally. I want to make sure it won't start doing this while I am out on the water.
