I have a 98 xp and ride it pretty hard and have flooded the engine a few times.
I remove plugs and turn engine over until majority of water is out - then heat plugs on a gas burner and put back and try start her.
Plugs get wet so i repeat procedure. I might go through 4 discharge / charges of the battery before she goes if it's a big swamping. (carbs under water)
Is there an easier way ? Is there a drain to easily get the water out the bottom of the crank ?
The suck / blow pipe off the crankcases to the fuel pump seems like a possible way of draining the crank but i don't know if it is located low down in the crank of not.
any comments would be appreciated
