Hello all,
Just found this forum through a google search looking for info on my old 1989 SP. It's been sitting outside in the weather on it's trailer for quite a while, because I had too many other projects. Hasn't been on the water since around 2006, and even then it was running rough and probably needed carburator rebuild then.
I just bought a carb rebuild kit on e-bay but don't have a clue how to do it. Hopefully my F-I-L will have a little time to help with the carb rebuild, or maybe I'll take it down to the boat shop. (?)
The motor or driveshaft was partially seized when I started looking at it early in the week, but I was able to get it turning manually by turning the flywheel by hand. Now it spins freely and smoothly.
I hosed out the engine compartment thoroughly because there was a lot of sticky gooey stuff in the bilge. The seat is down at the upholster's getting new vinyl. The padded handlebar cover fell apart in the sun over the past few years, so the redneck in me just zip-tied some foam pipe insulation around the metal bars to prevent head injury. If anyone can direct me to where to buy a handlebar cover I would be grateful.
With a new battery installed yesterday, the starter solenoid clicks, but no cranking. I jumpered across the positive posts on the solenoid. Big spark but the starter still won't crank -- have to assume the starter is seized? Found a starter on e-bay for ~$50 and ordered it.
Anyway, that's where I'm at....
Thanks for any input.
Marcus
Marcus
