I am sorry to have to post this. I have done all the searching I can and can't find my answer.
I have a 1999 seadoo challenger 1800 with twin 787's. Took it to the lake today, started fine, both engines ran great at low to mid RPM. At about 5000 rpm the right side started to cavitate. backed off the throttle and it went back to normal. I brought the boat to plane using mostly the left engine and then throttled up the right and it ran fine, topped out around 55mph. This happened over and over all day. Makes it tough to do a quick jump out of the hole. The wear rings are new and the impellers are in good shape. The drive shaft protector is broken off about halfway down on the right shaft. The ride plates and pumps all appear to be sealed well, I'll look at the carbon ring (if I can figure out where it is). Would that snapped shaft protector cause a problem? Also, on the left engine the speedometer cable enters the housing and is capped off. The same hole exists on the right engine but is not capped, should it be capped? Could I be sucking in air from there? On closer inspection I have noticed that the ride plate on the right side sits deeper in the hull than the other side, and the sealant is messy, would that hurt performance too? I've read about putting zip ties on a certain boot to increase pressure on the carbon seal, can someone give me a more detailed explanation on that? Could it be that the drive shaft is slipping under the higher load?
Sorry if this sounds vague, bad sunburn today, I can answer questions as they come in. Free case of beer for whoever can help. I can mail beer right?
