First Ride afte 10hr Service..
fearthisinc
Ok.. So I took the boat out today after getting it back from the 10hr service and had 2 issues come up.. First when I was launching the boat I started the boat up while waiting and it was fine.. I put it in the water and started it up and threw it in reverse but i wasnt moving but only because i wasnt in the water enough so i put it in neutral and it stalled out.. did this about 2 or 2 times when i would go from reverse to neutral... i could watch the rpm's just drop till it shut off.. anyway i finally get her in the water enough and start her up and back out and everything was fine.. took it around at high rpms and kept shifting it back and forth from reverse to neutral to foward and so on.. didnt stall out on me again but just curious as to why it might have stalled in the first place... the second issue i am having is the foward/neutral/reverse lever keeps getting stuck... i mean most of the time it was fine and i was shifting no problem but a couple of times i would be sitting there and throw it in reverse and go to put it back into neutral but i would get the lever almost to the N and it wouldnt go... or i would be in neutral and try to push to foward but it would get stuck halfway and wouldnt go foward anymore.. but i coulld go back to the original spot.. not sure what would cause this.. never had a problem until they did the 10hr service.. just wondering if there are any common problems that i should check before hauling it back out to the dealer since they dont open till tuesday... thansk
