bush
I bought my first PWC - 95 XP 717 and it came as a hull and several boxes of parts. LOL so I'm in for a challenge but on the plus side I've reassembled it without repair and everything is here.
1 - The engine: The orignal engine had a top end failure and the piston banged up the cylinder a little. It is not in terrible shape but the bottom end of the case was welded up and after I priced out the top end kit, honing, and crank work I bought a working engine from eBay out of a jet boat. 145 PSI in both cylinders and complete from stator to starter and all it needs is the carbs.
2 - Jet pump: good shape but I'm going to rebuild it
3 - Fuel lines old grey ones and I picked up 25' of new quality 1/4" ID fuel hose.
Any tips and advice on what should I test before I start buying parts and what should I rebuild / replace as I go along to ensure it'll run well?
Where would you start if this was your project (giving up is not an option).
see you on the lake
see you on the lake
