Exhaust pipe blockage/removal?
SaltyBones
From blowing into the tube that comes into this nipple I marked, it appears blocked at this point. Just to make sure before I do it...I do need to remove the exhaust pipe to clear this blockage...correct?
Also...What size are those 4 bolts on the top holding it down? Any tips on removal?
Unfortunately you will probably have to remove the pipe to get to that fitting. IF i remember correctly those are either 15mm or 17mm. I think there is also a bolt that goes through the support that is cast into the pipe that connects the upper pipe to the lower chamber.
So...four on the top and one on the side and it should break loose?
Also, I don't know if it's anything like risers on a boat, but I remember both mating surfaces must be filed down and evened out before reassembled. Is this the same for jet skis, or do I just grab a gasket and bolt them back together?
Just clean the surfaces and install a new gasket dry. I like to use some thread lock too because these do vibrate.
Any special care since they are exhaust bolts and hex (Hex bolts scare me anyway)? I sprayed some PB Blaster on them and will let them sit a day or few. I'm scared to death the heads are going to strip
You should be fine. SEA-DOO built these things to last. I've taken apart stuff that looked like trash, and it opened up.
I also go the OCD route and actually hit all the bolts with a wire wheel (bench grinder) before reassembly. Makes them all clean and shiney. Bolt right in smooth then. No crud in the threads.
You want to be sure to get the torque correct when you put it back. The parts expand when hot and if it's overtorqued it'll snap the bolts.
