Engine water ?
Well sick all summer from covid, so wanted to start ski out of water, so hook up water line, and did a dumb crap, turned water on before starting, water ran about 3 minutes, so I pulled plugs, let sit 10 minutes and than dry start for 1 minutes, should I try to connect my shop vac to water inlet to pull remaining water
I can’t see see anything wrong with trying that but is the water inlet going to the top of the cylinder cover? Might not draw anything more out that way. You’ve already pulled the spark plugs and cranked it over? Pit some 2 strike oil in the spark plug holes and let it sit for a second then crank over again, repeat adding a little oil and cranking till no more water is coming out and then try to start it. Once you get it going it would be best to take it out for a half hour ride
