Yes it's 951. Thank you, I'll be checking this soon. I'm just finishing up getting my other ski, the same year, make and model, running.Ur cooling system is blocked
Now it’s a case of disconnecting hoses and using hose pipe to flush the lines
Start at head and check from head to pump
Then head exhaust out let , remove little hoses on exhaust to see where flow exits
It’s just a case of checking where the blockage is and you may end up removing exhaust pipe
Confirm engine is a 951cc
Unfortunately, it's only fresh water. Thank you thoughIf in salt water , use salt away
No it’s fortunately fresh water, salt water kills jet skis. Over time if not maintainedUnfortunately, it's only fresh water. Thank you though
I just got my other ski running and I do see water in that one.
So, yes, it definitely has a block if this is what it is supposed to look like
No, it never does. So, these are the two houses I need top check, rightRemove the lines on exhaust and confirm you have water flowing through them
I have had the small water elbows and in-line connectors blocking up restricting flow
You can also heck you are getting water out of the exhaust system
If you are not then the cooling system flow is restricted causing the water to heat up causing the over temp
Remember it’s water flow you need and the amount of water coming from pump
Does it over heat on hose in the trailer ![]()
Can I just disconnect those two hoses and hook up two extra hoses to those two elbows that I have lying around to see if water is coming out? That way I can tell if the blockage is in the hose or in the elbow? This is all fine to test on hose water, right?
Yes, but these are the old 2-strokes.heads up new GTX's coming from the factory with loose house clamps....
Awesome, thank you. I just finished putting new fuel lines through it, replaced the fuel selector and got the carb back in. Fuel lines passed the pressure test so I'm going to get new fuel and then I'll ensure all the fuel lines and carbs are good, then I'll move onto the cooling hoses. Thank youI guess until you get the carbs fixed, you can't run the engine... When the time comes, if you can't find the clog in the cylinder elbow, you have to check by the pump or in the pump.
Here is a pic of the hose that goes from your cylinder head to the pump. The screwdriver is pointing to it.
Here is a pic of the water passage in the pump.
If its the jet pump cooling passage that is clogged, you'll have to remove the pump to get to it. Not a big deal though.
I undid this hose and nothing came outIn your picture, its the large one between the spark plugs you want to disconnect first. It connects to an elbow on the cylinder head. Unhook it and try to blow through the hose. Also, look into the elbow for a blockage. If you can't see a blockage with a flashlight, insert a zip tie into it to see if it is open. You can do this in your driveway. If you can't blow through the hose, the blockage is down by the pump.
After you get the main hose flowing, then check the little ones.
I had the ski hooked to a hose and that hose off the engine just went out the side of the engine compartmentWhere did you connect the water hose pipe too ![]()
Perfect, I'll test it tomorrow. Thank youYes. For water to come out of that hose it needs to be in the water.
But the test I did was correct? Disconnect that hose and wait for water to hopefully come out?Yes. For water to come out of that hose it needs to be in the water.
