kcr357
Thought I was finally out of the woods with my boat. Today I was going to take it into a canal for the first time this year, it always fired up fine. WHen I hit the starter today, it beeped four times. I thought it was a bad switch causing the mpem to read that is was in gear, so I took out the controls and checked everything out, it come out fine. While I was playing with the wiring, it started and ran ok. I shut it off, then tried to restart. Now it will turn over and run for a second max, then shut off. The if I keep pressing the start button, nothing, it wont continue to crank after it fires up for half a second. It seems when I move the wiring around in the dash area, it has some effect on if it turns over or is dead. Also, the dess was not communicating with the mpem sporadically, since the motor would not turn over and I was getting the one long beep. (I think, my beeper died and it makes a faint clicking sound. WIll try to get one today) Any ideas what I could check? I think there is a problem with the dess wiring, but not completely sure. Any ideas?
