My 01 GTS has aluminum mounts bolted on to the engine case. I bought another 717 that uses the belly plate. Will it line up to the rubber mounts ?
Also original engine is single carb, replacement has manifold for duel carbs. Can I just swap out manifold s. ? Thanks
