jimmaki
Unless the laser was mounted in such a way that it was proven or known to be square to the engine, it would not help.
In theory, you are looking to get the laser on a DOT on the other end. Getting the dot of the laser in place would be easy as you would learn or tilt the engine as needed. But in reality, you could be off by many inches as it is like a gun. I can be square to the target or off by 10 feet to the left and still hit the bulls eye...
Right, that's why I suggested to Soccerdad to face off an impeller tool square to the splines and insert it into the PTO. Then polish the face enough to reflect a laser dot. When the laser beam is emitted from the center of the impeller shaft using another impeller tool bored to hold the laser pointer, when it reflects back to the center of the emitted beam (meaning it disappears), since the reflective surface is square to the motor, viola, you should be dead nuts aligned.
I've never seen in person or used an impeller tool, but I'm assuming it fits nice and snug in the impeller shaft splines as well as the PTO given its real job is to act like a wrench. If it's a sloppy fit like the convex driveshaft splines, then all bets are off.
