Georgejlewis
I have a weird one I hope someone can help with. 1997 Seadoo GTX 800, I connect the key and get beeps (intermittent old) current going through the plug wires when trying to start but no spark seen at the plugs. I have replaced the spark plugs (br8es .024gap), grounding wire, new ring terminal on small grounding wire and connected with large wire at negative battery terminal, ignition coil, solenoid, rectifier, checked the timing, rebuilt the carbs (fuel is getting to cylinders with new non ethanol gas), replaced the battery, but it will not start or seem like it wants to. Plugs worn spark even when dry. Cylinders have 150 compression. I have ordered a new trigger pick-up but not sure that is the problem. I recently bought a used engine and went through it before installing it and all looked good. The previous owner gave me the "it an when I pulled it out".
Problem;
- Wont start!
- No visible spark from plugs
- Wits end
Thanks
George
Problem;
- Wont start!
- Wits end
Thanks
George
