guitarsjm
being a newbie, can this engines, guess its not an alternator, but a stator, can i wire a basic radio/cd with spkrs into the system? if so, what of the wiring harness should i connect to? i noticed that behind/underneath the steering console storage bin, against the inner wall are harness wiring plugs that i assume was just a general wiring/connecting harness for other models, using only what was needed for a specific boat model. besides, there is an acc fuse as well and another plug with a dead end connected to it that is right near the fuse block in same section that i assume maybe the accessory line(?). with a meter, it is a 12v line. but again, i think in the manual, some systems are alive with the DESS and some work with or without it being connected like bilge blower and pump. a little help with this would be great (almost ready to go!!). i saw a photo in one of the threads here with a radio and spkr(s) mounted on/in the side of the steering console... i hope i am not asking too much help. as far as a radio, i have no problem cutting out the area, but what kind of marine/boat radio housing w/cover would anyone here recommend...spkrs too. i was also thinking of a 12 lighter plug... any recommendations? love wiring and stuff.. thanks!:hurray:
