As I wade through an electrical problem with my ski... getting there with the help of the knowledgable... I created a pdf of the wireing diagram for my ski with numbers identifying each connection. If anyone can respond and enlighten us how each connection cound be tested I think it would help many people struggling with electrical problems... or at least I think it would help.
In addition .. anyone responding.. if you have some insight as to what may make each component die.. or why it may be popping a fuse, every little bit helps!
Corresponding to my wireing diagram attached:
1- Start/Stop switch - I think A simple continuity test would test this switch
2- DESS - again, continuity test with lanyard on and lanyard off
3- Buzzer
4- Oil/Fuel indicator
5- Speedometer
6- Oil Sensor
7- Fuel Sensor
8- Speed Sensor
9- Regulator/Rectifier
10- Stator/Magneto
11- Solenoid & Ignition Coil
Obviously some of these connecitons are more important than others... and maybe a connection can not be tested without a running engine or some other system requirement. Any little test that the ski owner can try to maybe fix their ski and save a ton of $$ at the shop is so appreciated.
Thanks
3- Buzzer
5- Speedometer
6- Oil Sensor
7- Fuel Sensor
8- Speed Sensor
10- Stator/Magneto
Thanks
