SabotageR1
I've come to the realization that early year sea-doo can be a nightmare to work on when purchased used. So many things that can go wrong that all illustrate similar symptoms. Examples:
If you put the stator position off, it appears to be a carb issue. Why in the world would seadoo make it that you can put it wrong. Most other mfg's there's only one way a stator can go on.
If your rotary valve cover is not within spec and doesn't start. Appear to be a fuel or carb issue as well, when the fuel is ruled out. appears to be an electric issue.
If your vent valves are bad, seems to be a fuel or carb issue.
If your engine seals are bad and 2 stock oil gets in the engine, won't start, seems to be a fuel or carb issue.
I see why shops say they don't want to work on these old ski's. I've been reading post after post of people with seadoo issues and I find it ridiculous that these people have to go through a whole list of checks and repairs to find out why their ski won't start.
