I basically took my engine out today, to replace one of the four engine mounts for my 717 engine. I put the drive shaft in first then the engine with the shims in the original position i then bolted the engine down but not fully..i then slid the drive shaft into the PTO without much force it went in smoothly...then i put on the jet pump assembly in and letting it slide in the shaft. I then turned the engine over in the attempt to align the shaft to the engine. I then tightened the engine down and cranked the engine and the shaft spins well but wobbles, I am not sure if its not aligned properly or what would cause this but I am pretty sure the shaft is not bend.
ANY SUGGESTIONS OR ASSISTANCE IS GREAT APPRECIATED.
