One of my drain plug o-rings cracked in half and fell off. The other isn't looking so good. I found on the forum that the size is 12 at ace. My question is how do you remove the drain plug without breaking the retainers so that the new o-ring can be installed?
2 ways, reach into the ski and bend it sideways and pop the plug out OR take the 2 screws off and remove the whole drain piece, install your new o ring and then re-install. Use some silicon when re-installing for a good seal.
You'll find it easier to just remove the screws and take the whole assembly out. Chances are you're gonna break it with needle nose pliers. It's a great idea on paper but in reality not so much. Only reason I say that is because I've been there and done that.
A good quality o-ring will be pliable enough to stretch over the cap without breaking. I have done this several times. Much easier than removing anything imo.
