makaveli07
Hi this being my first year of owning a PWC (1997 Spx), I went to winterize it as summer is all over here in Vancouver BC. Without thinking much I watched a Youtube video of a guy who used a drill pump to pump marine antifreeze into the engine without turning it on. So i followed... i pinched the hose to prevent antifreeze from coming out the back and proceed to pump antifreeze into the engine till it came out of the pisser in the rear. And fogged the carbs and cylinders. Then while doing more research i found out some people flood the engine by doing that. So i took the spark plugs out and cranked the engine nothing came out ither than some fogging oil. Oil tank looks good (not contaminated. I started the ski started fine lots of smoke from the fogging oil. But nothing out of the ordinary; antifreeze shot out when i blipped the throttle instead of water. So my question is how do i know if i flooded the engine with antifreeze? And when an engine gets flooded is it usually the cylinders that flood first or the crankcase ? Should i be worried ?
Thank you,
Thank you,
