I have a Di engine i have rebuilt. It failed the leak down test. I found it leaking between the head and cylinder. I used a new SD head gasket when I installed the head. I removed the head and found it warped .011. I got a used head that is straight and installed it. I re-used the SD head gasket. It is leaking in the same place. Question; can I reused the Di head gasket? I installed it once and removed it immediately. If it should not be used, is it ok to use only for the purposes of testing.
Thanks!
Thanks!
