Curious about blower life?
usacodeaf
I went and bought a 2007 Seadoo Challenger 180, when I got there the blower was working. The fellow I bought it from said he accidentally left it on too long, shut the blower off then started up the engine, motor ran well. I bought the boat brought it home and now the blower won't work. I'm curious to ask if I can change the switch to one of the other ones and just test my blower on/off switch that way? I already checked the fuse and it was fine. I was thinking of checking the switch next, then if it still doesn't work I can just replace the blower motor. Any tips or ideas of anywhere else I should look? Thanks!
Try tapping on the blower motor with a screwdriver while the switch is on. If it starts running , the motor needs to be replaced. Switch is easy to test. Just bypass it. Motor should run.
