crankshaft seals
lilpain
my xp is spiting out oil mixs fron one of the spark plug hose its it possible to just replase the seal with any special tool. or do i need a new crank
i bet one of the needle seats is stuck and dumping gas into the cylinder....did u just do a rebuild on the carbs?
yes i did can u tell me how to check on that you are talking about the needle seals or what is it
You need to take apart the carbs again and re-clean the needle/seat (the needle that moves up and down with the spring). Then put a small coat of wd40 on the needle/seat. You should also do a pop-off test (search for it on the boards there is TONS of help on how to do it)
