Crank case oil in 96 Challenger 780
Yooper Dooer
Hello again friends! I am in the process of changing out a cylinder jug and have both jugs removed to change the gasket. I can't find the Allen head drain plug talked about in other threads but I was wondering if there is a way I can change the oil in the crank with the engine still installed but with the jugs removed... Also should I use 30wt oil or injection oil.... Thanks,,,
