shucky
08 seadoo gti 155 se,
I've had the ski for about 1.5 -2 years now
Anytime I start the motor I have to give it a bit of throttle at the same time while pushing the start button which in return is causing it to flood the carb ( the flooding bit has just started). it don't matter rather its just been put in the water or if I've had it running for a period of time, its a bit slow cranking over as well.
2 while riding idel mainly I can feel and hear what seems to be a serge ( eg. drops in rmp) which seems to be pretty constant.
3 the Ski seems to be ideling a bit high to me, not sure what the rpms are due to the speed-o gauges not working ( next project).
I'm just wondering if anyone else has had these symptoms and if so what was your out come result.
I've spoken to the mechanic I use for its services, due to having to connect the ECU from my ski to another ski in order to program a key for it (old key kept falling out) he seems to think the cause of that is either the ECU or main wiring harness has anyone got any thoughts on this as well.
Cheers.
Shucky
Cheers.
Shucky
