Straight from the manual from my Speedster. Sorry I had to do it as an attachment I couldn't figure out how to embed it into the post, sorry. If someone wants to embed it please do or tell me how to do it and I'll fix it. It clearly states the
IF the engine has been water flooded water
MAY have been trapped in the balance shaft gear and bearing cavity. They then go on to tell you to check the oil to make sure it's good/bad. so if there is no oil in there why would they tell you to check the oil? And then proceed to tell you to
REPLACE the oil????
Now if you look at a picture of the cases you'll see that the case where the crank is also has a low spot, could that be holding your missing oil, possibly, but it does look like it SHOULD drain back down into the cavity. The other thing to think about is this, IF that oil were to be drawn out of that cavity what is going to replenish it? There are no lines, or passages that go to it. I've done three complete tear downs and rebuilds of 787's all three have been the same. And the way the two stroke works is the gas and oil enter the case and are sucked up through the transfer ports in the cylinder walls and into the combustion chamber and the mist will coat the bearings, so it's not like the gas and oil is going to pass to the far reaches of the rear of the case through a labyrinth washer go around a gear to lube those bearings. What happens to bearings with no oil? KABOOM! There has to be oil in there. Also if the oil was going to be sucked into the engine, why would Bombardier install two seals on the CB shaft if they knew the oil would get sucked into the engine, honestly, think about it? And look at the bottom case of mine(bottom pic top left cavity in the case), see the shit stain in the CB cavity, that was from the pitch black oil that was in there from 96. Yet another thing, the MAG end of the CB shaft has a permanently lubed SEALED bearing (orange seals on mine), why wouldn't Bombardier just put them on both ends of the shaft, if the oil is going to be sucked away? You have to remember 1 oz of oil ain't shizz, the bottom race of a bearing has a lip and could hold oil in there, oil also can transfer through the end bearing and get trapped between the end crank seal and the bearing too. That end crank seal needs lube too, the PTO is rotating on that seal at 7K, rubber and steel don't mix well with out lube, no place to put grease on the seal? So 1 oz. can get dispersed quickly. But when flinging around off the gears there's enough to coat/mist bearings, gears and seals to keep them alive. I'm not trying to be a PITA about this just trying to shed some light on it. It is truly amazing how deep a thread can get on such an easy question about what oil.
View attachment Oil.pdf
Now here are my cases for my 787, the red crank seals(in the center of the crank) seal the R/V from leaking into the crankcase. We all know when the seals leak the ski's smoke really bad and can really drink the oil, so the oil doesn't transfer that way, there are no lines that go back to the balance shaft and no internal passages either. We also know there is an in and an out oil line for the R/V shaft.
Bottom case, No oil passages.
In this pic you can see the oil line on the CB gear. The clean gray spot is where the oil covered the gear and the brown is light rust from siting with no oil
