Guys
I have a cooling leak on my 2006 rxp that I just purchased. The coolant is leaking is externally of the motor because it is accumulating in the bottom of the hull. It only seems to leak when it is hot because I cant find it by just running it on the lift. I have checked all the hoses and connections and everything appears to be tight. I have not run a pressure check because I don't have the equipment to do so but before I take it to the dealer I wanted to see if there is a common area that has leak problems. Thanks in advance for your help.
