Rossterman
Reading most posts, it seems that most explain that the water box regulator reduces water flow to the tuned pipe at higher speed/rpm. Something about less flow to allow,the engine to make more,HP and rpm. Looking at how the diaphram and needle valve work, the needle rises under higher pressure into the body as the diaphram fills which retracts the tapered needle and closes the hole in the bottom that feeds the muffler (on which it is mounted). That would mean more water flow is diverted at speed rather than less- exact opposite of what is commonly thought. Am I missing something?
