Today was a bad day...
I was out on the lake when the left engine started to run unusually rough. It has been ruunning rough for a few months now but this time the engine seemed like it was about to knock itself off the mounts, and it was making a loud knocking noise. I turned it off and checked the plugs. They were dark brown, which i believe means that they i am not running too lean. I put them back in and started it up again with the same problem as mentioned above. I turned it off again and this time when I tried to start it, all I got was a click. I took the output shaft behind the motor and tried turning it by hand and it had significant resistance, almost like it was jammed or something. I ended up limping back to the dock with my good engine and, an hour and a half later, loaded it back on the trailer and went home. When I got it home I took the carburator off. Don't ask me why because I don't know. And beneath the carb in the port that goes into the engine was a peice of metal about 1/2" long by 1/8 inch wide. Red flags went off in my head and I am thinking that I have very big problems. If I have bent the crank or a piston that would explain the rough unbalanced motor that wants to bounce off the mounts. Here is my question..... Does this mean a complete rebuild? SBT sells new engines for $750. I cannot take the boat to my seadoo dealer because they are very very dishonest and shady. Any ideas, opinions or help would be greatly appreciated. By the way it is a 98 sporster 1800.
P.S. how hard is it really to pull the entire engine. I am mechanically inclined and have rebuilt my motor in a 69 f100 pickup, but never a 2 stroker.
