Thermal shock...
While at some point, I used to think thermal shock could affect our operation, I have since moved away from that theory. The Rotax is set up for preheating cooling water as it comes through the tuned pipe.
But, cold air is denser. In your fuel/air ratio, you might find that the engine a bit sluggish in winter riding verses summer riding, when air is hotter, less dense.
Air temperature and altitude play a significant role in the jetting and tuning of our carbs.
I would say, give it a shot. You'll know from the response if it's too cold. But, before making that decision, allow your engine to warm up. You might find you'll need more choke until it's warming enough to lean out by releasing the choke. If so, starting at full choke, then holding your choke at half might help keep it running till it warms up.
But bottom line, you should have no problems running in colder temperatures outside a possible low speed adjustment open........:cheers:
