Cleaning strainer on 2006 GTI - p1544 error code
boulaa
Get the P1544 exhaust over heat code at WOT. Runs ok between 6000 -7000 RPM's.
Never run in salt water. I flushed the engine to see if water comes out of the pump and it is ok. People mention cleaning the strainer because there might be a clog...but I thought flushing it would do that. How do I manually access the strainer ?
Also they mentioned to check the 3 little holes in the Y pipe to see if one of them is clogged. Does anyone have pix or video of this. I'm assuming it is the stainless steel pipe. Which end of pipe has the hole...the bottom or the top...engine side or muffler
Thanks for any help. Don't want to bring to a dealer if its something easy to check and fix
thanks
Al
