Mitzubshi1
Hi all.  I have a couple questions about caring for my 1994 GTX.  First question is about changing the oil in the jet pump.  I hear a lot about being careful not to damage the o-ring.  Why not just take out the oil plug, let the oil bleed out, then fill it back up.  I realize some of the old oil will be left in the cone, but this would not only save time but also reduce the worries about damaging the o-ring and also loosing a good seal.  Has anyone ever tried this method?  I'm not one to be lazy on maintenance, so if pulling the cone is a necessity, I have no problems doing it.  Second question is about my speedometer- it doesn't work.  Are there any simple tests that can be done to troubleshoot what needs to be repaired and/or replaced?  Spinner wheel moves freely and all connections look good.  Thanks in advance.
