kcr357
I've started calling my boat Christine after the car, except instead of it fixing itself from being broke, it inexplicably goes into a non working state from merely sitting in my yard under the cover. The second to last time I took it out, it had a fresh wear ring, but I didnt replace the neoprene ring so it was cavitating badly. However; it ran like a champ all the way to redline, very clean running, no misses, reminded me of a good running 2 stroke mx bike. I re sealed the ride shoe and pump, took it out again, and now it wont rev past midrange. It is smoking a little more than before, the motor does not seem to be laboring, its almost as if the throttle isnt opening all the way(it is). I cleaned the carbs this spring, but may end up doing it again(does not have the grey fuel lines, internal filters are clear). Another symptom is it does not want to idle, I have to goose the throttle when its running to keep it going. Will get a plug reading tomorrow.
