pwrtech195
Help! I am working on my uncles 1997 Challenger Jet boat and it is not achieving full rpm for more than a second or two.I give it throttle from any speed and it revs out to 7000 for only a second and drops to 5000 rpm then it will surge/hunt. I have checked the gas and no water, fuel lines have been changed to black (fuel separator was removed?), carbs cleaned and rebuilt, rave valves cleaned and checked. Before the rave valves being cleaned it would only go 15mph and only rev to 3000rpm. Spark plugs have been changed and are looking grey/brown on the tips. I noticed water leaking from the front cylinder at the cylinder/exhaust gasket near the bottom and it looks as though it has been leaking a while. The exhaust manifold connection with 4 bolts to the muffler looks like it has been removed (red RTV) I am going to remove the exhaust and replace the gaskets but I don't think this could be it could it?
The engine revs great out of the water on the hose.
Will not rev (rev limiter) when in nuetral.
Checked the "rave looking valve" on the muffler can and it is freely moving and lines are clear (Water regulator).
