steve on the water
So my trials this year continue. My engines are starting quickly and running better than ever. Having the carbs installed properly was not surprisingly a big difference. The throttles are matching RMPs when aligned for the first time ever. While pulling the boat after water testing for the carb fix, I noticed an audible leak. Water was rather quickly running from under the starboard engine. Since we were done for the day, we packed up and I assumed that the carbon ring was shot. I ordered one online and planned to head back to the lake this weekend to fix it. A quick look at the manual and the internet prior to leaving told me that this was not likely the issue since he water was coming from below the engine. It is coming in pretty quickly, the bilge pump need to kick on every minute or so.
Fast forward a week. I splashed the boat on the trailer and it started leaking before the engines were started. I had pulled the covers over the shafts and they were both dry. The dripping water sound appeared to be coming from the muffler/resonator on the port side. The water appears to be leaking from under the starboard engine. Is there a valve that could have gone bad to let water back through that path. I am wondering if a hose cracked under the engine that feeds into the exhaust. I tried to get a look with a mirror, but was unsuccessful. I wouldn't think this would start leaking very quickly though. Running great, just not sure of the path of water intrusion and what damage it may be causing.
Just one more issue to deal with.
