Noahsfixingbrokedownskis
Is there any specific tube that I can buy to replace the carrier bearing tube that is used in lieu of the carbon seal to seal the drive shaft. My 97.5 gray ghost had a carrier bearing and the tubing was torn up and bearing froze. I bought a new carrier bearing setup from osd but it didn't come with the tubing. Is there a certain type of tubing or hose I should buy and a set length? Also does I just tap the carrier bearing onto the driveshaft or is there a c clip like the carbon seal version that holds it in place?
