Having some issues with my old 2001 Sporster LE. This boat has a two cylinder carburated 951 engine. It ran pretty good all last season although by the end it was taking a little while to start...
Fast forward to this season we go drop it in the water and are finding we are having high idle issues and the carbs are sticking. Get the boat back on shore, pull carbs, and find the throttle butterfly on the PTO carb a little bent, carb not opening smoothly, carbs are all corroded, adjusters not working.
We ended up buying brand new carbs and just installed with fresh gaskets. Installed fresh BR8ES plugs and gapped to .022. Replaced all the old grey fuel line with fresh line from west marine, new clamps on everything.
Set low speed adjuster on carbs to 1.5 turns out as per manual.
Boat starts immediately now on first crank, but the idle is high. 4000rpm plus out of the water, and it will rev to the limiter sometimes. This is with the idle adjuster all the way out, and the throttle plates are closed totally with the cable loosened
I am thinking bad fuel? Not enough fuel? (although the fuel filter was full) Or an air leak somewhere?
I checked for leaks, couldn't find any, the gaskets are fully seated and carbs are tight. Compression is 140psi + and even on both cylinders.
I am afraid I am going to damage it trying to troubleshoot it. I am also scared I didn't get the oil pump synched good.
Anyone in Long Island NY that can work on it for me? Willing to pay what it costs to fix.
