carb removal
rjgooden
I have a 93 doo that is not running on the rear cylinder. It will run if I spray fuel in the rear carb, So I think it is probably the carb filter, from all the other threads I have read. Here's the questions. How do I get to the screws on the bottom of the carb that hold it to the intake? I followed another thread to some pictures but they start with the carbs off the craft. I have tried to get a wrench on these nuts but it seems impossible
Do you meaqn the four bolts on the side of the motor? the picture shows the carbs removed from the manifold? Will I need new gaskets? Can I get to the filters without removing the carbs? I only need to get to the back one?
nope, the pto(back) carbs' filter, is facing, the mag carb.
The 4-13mm bolts, securing the manifold onto the case, is what you need to get to. The one, front bottom, is the pita, but can be got'en to. No gaskets/o-rings needed, but when you do get bolts off, the rv valve, behind the manifold, will stick to it, so make sure, you got a flathead to push it back onto the gear, or else need to re-time it.
Thanks, I will try to get it out of the water today and give it a try. Anything else you can think of to look at while I am at it. The previous owner has already change the gas lines and selector
