Carb Rebuild
manolocross
So i rebuilt two carbs for a buddy of mine of his 94 seadoo xp with a 657 x engine..sitting for ten years with gas..the carbs are sbn 38i...i set the pop off on the mag carb to 22 psi but the pto carb i could not get it below 30 psi no matter what spring i used.... does the pop off setting have to be identical between both carbs???? i read at seadoo source that the proper popoff for this model is 21 psi...is this correct?What problems would this cause???:bigear:
