Replacing a 787 motor that is locked up. And whenever I replace a motor or do a top end I like to find out what caused it and fix it so it doesn't happen again. So I started looking at the carbs to clean and rebuild. And I think I found the problem. The linkage was way out of adjustment between carbs. Also noticed the throttle plates will not move without a lot of manual force. So before I go destroying the carbs or replacing them when I don't really need to is there a way to fix this? Anyone ran into this before? Surprising thing is when I opened up the carbs they look super clean!
