I have a 97 GS with a stock 717 engine and single mikuni carb. I recently replaced the original fuel lines and did a carb rebuild at the same time. After putting it back together, the throttle action is not smooth. As I give it more throttle from start it does not increase the rpm smoothly. I pulled the carb to check it out thinking that maybe the pop off was out of specs. It reads 40 psi, which is within the 23-43 spec range for a 1.5 needle valve and I used the 95 gm spring (dull silver?) which looked like what was in there originally. I set the low and high speed adjusters to the minimum adjustments (1 turn low and 1.5 turns high) after rebuild. My guess is that these need to be fine tuned. Any ideas? Thanks
