When replacing a carb, how do you re-tension the throttle springs without tearing up your fingers taking lots of time? Is there a tool for it?
Also, the 2 M8 x 75 Socket Head Screw that hold the carb to the manifold, fiche shows you should apply synthetic grease. I had the carb come loose after doing that. Should I have used Loctite instead? If so, blue? or red? How much should they be torqued?
Any trick to re-attach the cable from oil injection pump? I spent a fair amount of time getting that connected too.
Maybe I'm a klutz, but there must be easier ways...
